Gear motor and gearhead line
A full line of gear motors and gearheads has been designed to pair with every servo motor, creating complete gear motor solutions rated from a low of 50 W to as high as 15 kW.
A full line of gear motors and gearheads has been designed to pair with every servo motor in the full Sigma-7 range, creating complete gear motor solutions rated from a low of 50 W to as high as 15 kW. Five different gear ratios are available, ranging from 3:1 to 50:1. The gear motors have been designed with precision helical gearing with a 40% greater tooth surface area for smoother, quieter, and more accurate operation, an enhanced system of bearings, including 45% larger planet bearings for guaranteed alignment, and balanced, concentric shaft couplings to minimize vibration during high speed operation and reduce the inertia of the gear motor system.
Yaskawa
